- Maryland, USA ??
Sexy!! Hey, you might know. What temp should I set the high limit safety for? It goes up to 250f. I’m thinking 220?The 55 supreme is a great all round engine. Run it in my w5. Plenty of torque. View attachment 82685View attachment 82684
Awesome!!Taylor 55 supreme is ordered and 30/54 gears as per their instructions.
The ikilly doesn't work with big bore, its a different ignition system than small bore.Sexy!! Hey, you might know. What temp should I set the high limit safety for? It goes up to 250f. I’m thinking 220?View attachment 82686
How much rpm does it get? I have the 50GT and it has tons of torqueYes and it’s a lot of power.
You just need a bigger ring terminalIkilly wouldn’t work with it. No idea. But it screams!
The “ring terminal” is only for temp, I had it around the decompression plug. Which wasn’t rite but it worked there. Temp readings were perfect.You just need a bigger ring terminal
It reads the rpm through the kill switch wires. I had it reading the rpm’s but the vibrations were making the screen glitch and shut off. It was killing the engine too. It’s on my shelf of stuff that I wish I wouldn't have bought.
