That may be true, but in my case, I've yet to see any wear. Maybe I didn't get them hot enough to make any difference, I don't know. Maybe there was nothing wrong with mine. I don't know.Martin said:The only way to make gear better is to case hardened them, so try to tempered a gear will only accelerate the wear.
My Rampage gear mesh was terrible at the center diff and the gear plate when I got my truck.csp1971 said:That may be true, but in my case, I've yet to see any wear. Maybe I didn't get them hot enough to make any difference, I don't know. Maybe there was nothing wrong with mine. I don't know.
rc-driver didn't do anything to his gear, temper it or anything until after his first run. So since it's messed up, I don't think he runs really any risk with tempering since it already appears chewed.
Yey !!!!!!!!!!!Martin said:Apparently there is no premature wear with steel gear on Rampage, but if for any given reason someone have issue and need a real steel case hardened gear, you have to look here:
http://www.gotpetrol.net/steel-gears-vt4838.html
He have more gearing ratio available than the factory.
Absolutely true.grf said:..........(if a gear wears it looses the case hardening and involute shape and that is the end of it) .......
