Thanks to RedcatRampageForum
RCDAD said:
The boots allow you to pack the cup with grease. They stay on pretty well with a small zip tie.The axles don't have enough play to fall out of the cups. You can set the droop screw on the lower suspension arm to limit the amount of downward travel.
Droop screw???
My DR has tabs on the chassis that limit downward movement
Phill said:
Droop screw???My DR has tabs on the chassis that limit downward movement
The tab is where the droop screw makes contact. This is where it is located on the suspension arm.
Yep sure enough they're there
Do you ever stop learning about these things?
I think the next one I buy will be in kit form so I know all about it before I start running.
I had my MT a year before I realized there was a screw that held in the wheel adapter pin. LOL
