Redcat2
Gonna give these servo's a try. I have used Futaba everything on my planes and heli's. Figured I would try these out cause they are cheap and because I am BROKE! LOL
Steve
Futaba S3306
Control System: +Pulse Width Control 1520usec Neutral
Required Pulse: 3-5 Volt Peak to Peak Square Wave
Operating Voltage: 4.8-6.0 Volts
Operating Temperature Range: -20 to +60 Degree C
Operating Speed (4.8V): 0.20sec/60 degrees at no load
Operating Speed (6.0V): 0.16sec/60 degrees at no load
Stall Torque (4.8V): 266.5 oz/in. (20kg.cm)
Stall Torque (6.0V): 333 oz/in. (24kg.cm)
Operating Angle: 45 Deg. one side pulse traveling 400usec
360 Modifiable: No
Direction: Counter Clockwise/Pulse Traveling 1520-1900usec
Motor Type: 5-Pole Motor
Potentiometer Drive: Indirect Drive
Bearing Type: Dual Ball Bearing
Gear Type: Nylon Gears
Connector Wire Length: 12"
Dimensions: 2.6" x 1.18"x 2.25" (66 x 30 x 57.1mm)
Weight: 4.52oz. (128g)
Price:
$39.99
Part:
FUTM0020
Steve
Futaba S3306
360 Modifiable: No
Price:
$39.99
Part:
FUTM0020
