The Bearing Gods
hasgas
SE Michigan
Just wanted to turn everybody on to a specialty bearing shop in Toledo Ohio. I was scratching around looking for a 10x22x6 bearing for the FG and was finding out its nearly impossible to order/get a single bearing, especially if most suppliers seem to be out of stock on a particular size.
Driving to an unrelated local I passed G & J Bearings and Supply in a dimly lit alley, no really, a small ma and pa shop in an even smaller building, and wondered in. Not only did I get my bearing, I was also educated on the process of manufacturing rubber seal bearings vs. metal sealed bearings vs. open faced oil bathed bearings, rpm ranges of each of these types of bearings, and the max operating temperature of each. These guys Know bearings.
He even was able to spec out the ceramic alternative, and had the thing in stock!!
So, if your looking for the impossible to find little bearing, in a pinch, want to be educated, whatever, give these guys a shot, they really know they're product:
615 Phillips Ave
P.O box 6766
Toledo, Ohio 43612
Ph. 419-476-8133
Fx. 419-476-3313
You will pay a little more than usual, but these are NOT hobby grade bearings, and you get what U pay for........:)
