"The clones"
How about here guys.Just click on the friehammer/traveller parts:cool2:
http://www.fg-hopups.com/index.html
I will admit the guy is great when he gets back to you and I have never been taken, so I do trust him and his parts have made a difference. I'm just like everyone else eager and impatient and my expectations are high and will rave about anyone who meets or exceeds my expectations.:)
Thanks teamchrome for the part #'s! I just ordered what I was told is the last beetle conv. kit at largescalerc.com. I'll let you know how it goes on. Hopefully it will just bolt on. I had to get one while they were still in my price range being that fg doesn't have the license to sell VW anymore.--nate
Well, I got it to fit and it looks awesome! I put 23mm adapters on the back with proline 40 series mashers, and 14mm adapters on the front with savage X tires and it looks like they were made to fit. I still can't figure out how to post pics, but I'll keep trying.--nate
All of the FG tires and rims will bolt on a firehammer with no problem including Monster Tires
FG Part Numbers that work on the Fire Hammer. Some minor modifications may need to be done.
06011 Side guards l./r. each 1 pce. 18.59 18.59T
06023 Servo saver A/B, 1pce. 8.06 8.06T
06024 Servo saver pivot, 1pce. 4.55 4.55T
06026 Steering rods M4, 2pcs. 2.54 2.54T
06030 Steel balls 10 x 10,75, 4pcs. 8.97 8.97T
06031 Roll cage, 1pce. 14.30 14.30T
06032 Brace f. roll cage long/short each 1 pce 10.99 10.99T
06033 Wing mount, 1pce. 10.27 10.27T
06041 Pinion shaft 10 mm, 1pcs. 14.95 14.95T
06042 Brake plate and square, 4pcs. 13.78 13.78T
06044 Brake disks, 2pcs. 12.61 12.61T
06048 Steel gearwheel 48 teeth big, 1pce. 38.35 38.35T
06049 Clutch bell, 1pce. 37.05 37.05T
06050 Plastic gear carrier 60 mm, 1pce. 7.48 7.48T
06051 Dampening rubber, 4pcs. 5.40 5.40T
06061 Rear axle mount left, 1pce. 8.45 8.45T
06062 Rear axle mount right, 1pce. 8.45 8.45T
06064 Differential housing, 1pce. 16.12 16.12T
06065 Differential cover, 1pce. 6.76 6.76T
06067 Differential gearheel B, 2pcs. 35.04 35.04T
06068 Bevel differential gear axle, 1pce. 4.42 4.42T
06075 Rear upper wishbone pin, 1pce. 5.85 5.85T
06082 Gearwheel cover, 1pce. 5.85 5.85T
06096 Shock retaining screw M5, 4pcs. 6.31 6.31T
06099 Front shock mount, 1pce. 9.75 9.75T
06104 Front driving axle 55 mm, 1pce. 6.76 6.76T
06105 Wheel 1:6, white, 2pcs. 32.37 32.37T
06106 Square wheel driver 9.5 mm, 2pcs. 7.54 7.54T
06108 Off road tire stock M compound unmounted 55.77 55.77T
06116 RC-plate Futaba, 1pce. 10.66 10.66T
06135 Engine mount large, Zenoah/Marder, 1pce. 11.44 11.44T
06414 Tire inserts f.6108/6409/6411, 2pcs. 9.36 9.36T
06431 Steel gearwheel 16 teeth, 1pce. 22.75 22.75T
06540 Receiver box, 1pce. 8.58 8.58T
07088 Volume compensation f.shock absorb.,2pcs 3.06 3.06T
07089 Shock piston 2 pcs. 3.06 3.06T
07092 Spring plate 2 pcs. 3.38 3.38T
07094 Swivel nut M16x1, 2 pcs. 9.10 9.10T
07095 Adjustable ring 2 pcs. 9.10 9.10T
07102 Front wishbone pin, 2pcs. 7.02 7.02T
08092 Shock fastening pin/set collars 3 pcs. 3.19 3.19T
08097 Front axle trestle A, 96 1 pcs. 9.36 9.36T
08098 Front axle trestle B, 96 1 pcs. 9.36 9.36T
08140 Alloy plate for front axle 1 pcs. 10.01 10.01T
08348 Tank Solo complete, 1pce. 48.36 48.36T
06027/05 Ball-and-sock.joint 6mm f.M2screw thread 4.16 4.16T
06027/06 Steel ball 6 mm, 5pcs. 4.55 4.55T
06029/01 Ball-and-socket joint 10 mm f.M8, 4pcs. 6.37 6.37T
06072/01 Adj. rear lower wishbone 1:6, 1pce. 11.83 11.83T
06076/01 Rear up. wishb.thread rods r/l 61mm,2pcs 12.09 12.09T
06081/01 Ball 5/10x15 M5, 4pcs. 11.44 11.44T
06100/03 Turnbuckle right/left, 32 mm, 2pcs. 9.23 9.23T
06134/01 Engine mount small/G230 RC/Marder, 1pce. 6.76 6.76T
07070/01 Rear shock mount 97, new, 1pce. 16.64 16.64T
07087/02 Lower shock retaining, long 2pcs. 3.06 3.06T
07103/01 Front upright 12.10 12.10T
FG Part Numbers that do not work on the Firehammer
06039 Gear carrier plate, 1pc. 20.67 20.67T
06045 Brake operating shaft each 1 pcs. 7.48 7.48T
06071 Alloy gear plate, 1pce. 11.57 11.57T
06079 Rear driving axle, 1pce. 18.14 18.14T
06080 Rear dogbone, 1pce. 11.25 11.25T
06423 Gear wheel protect.f. 42/44/46/48 t.,set 18.46 18.46T
06427 Plastic gearwheel 46 teeth, 1pce. 12.74 12.74T
06428 Plastic gearwheel 18 teeth,1pce. 7.67 7.67T
06481 Alloy shock absorber 2000 long, 1pce. 28.93 28.93T
07087 Upper shock retaining, 2pcs. 3.06 3.06T
08100 Front lower wishbone 1:5, 1pce. 9.10 9.10T
06010/01 Alloy chassis Zenoah 1 pce. 128.70 128.70T
06028/01 Track rod right/left 1:6, 74mm, 2pcs. 8.06 8.06T
06066/01 Bevel diff. gear A, pluggable, 2pcs. 39.91 39.91T
06069/01 Diff.driving axle, pluggable, 1pce. 18.46 18.46T
06137/01 Bolt f. gear unit 24,5/26,5mm, 3pcs. 5.46 5.46T
08100/01 Front upper wishbone 1:5, 1pce. 9.10 9.10T
team chrome where did you get that list from?
cause there are some diff parts on there that DO NOT FIT THE FIREHAMMER...... I pointed that out too some Fg dealer and they just laughed at me.and said who cares cause the gears are 90.00......... ALL the BEVEL gears DO NOT FIT the firehammer OR the Output cups/drive cups not matter what an FG dealer tells you.......they are not the same Fgs are 8mm and Firehammers are 6mm
Same as on Molzers site.
Hellya is good people just work has to come first.
He is local to me and if he doesn't get the parts any more who will??
Sounds like he is getting out of the hobby.
Some of these dealers in the states need to pick up were Mark left off.
I agree, we can't let those parts not be available to the US users. I really think Chop (or others with the skill) could make some money here and get them (motor mounts) to some dealers or do it themselves. :)
What they let go on and still are from what I hear in that post over at the "crap forum" to a vendor, that gives money to there site, was and is wrong no matter what! Funny how it started with bashing members to members and now has lifted to vendors. I and others I know received all our items from him when he said they would arrive and he kept in touch with me on the items as well.
It's too bad, I understand being frustrated with a company not responding I just think I would keep pounding the frustration at the company and not make it a bash session or feeding frenzy (If that is what happened).:(
Shown at RCX there is ANOTHER KNOCK off but wow the build quality of the samples showed were better then smartech / carson
Spotted at RCX.
CY motor
Knockoff of a FG Sportsline car
RTR with radio est. price $699 built painted and ready to go go go.... :eek:
Company was said to be started by a former Smartech sales manager it looks exactly like a carson / smartech. The build quality of the car is fantastic looks even better then smartech, servos are GWS 777.
Body and radio is where they fell short (for now), 27MHz AM Futaba knock off china radio and a non lexan white plastic painted / decal Ford GT
LOVE the Ford GT shape just wish it was lexan and more detail it is said to be a licensed body.
US importer is set, I was told there are PARTS O PLENTY so I am told, yeah we will see. Importer is in Alhambra California I am going to take a re-con visit to check out parts supply ;)
Mark was in it for the love of the Hobby, not for $$$$ of it.....He cannot help that it takes them Germans forever to ship him his products:no: :no: ...Mark has never steered me wrong, and has even sent me a couple things for my FH in a pinch when I needed them......I wish there were more SUPLIERS/DEALERS around like him instead of trying to make a quick buck on this hobby..
