The fastest was to change MT5 V3 clutch spring
Slasher
What is The fastest and Easiest way to change MT5 V3 Stock clutch spring to the new DDM 7500rpm spring
any videos or pictures would help
you'll have to remove the gear plate first, I have a thread on it:
http://www.redcatrampageforum.com/showthread.php?t=3938
Then you need to get a piston stop (in a pinch you can use a pice of rope that won't fray) and your good to go..
There is some other threads on tricks to removing / re-installing the actual spring...search about you should find info easy
