these boots fit
Those boots are ok hostile makes a gray set I've had better luck with the gray set they seemed to lasts longer, . I love boots they keep the dogbones greased and dirt out the cups
wont fit unless you run cat5 mfg(or similar) diff cup rings. they will be very loose and will most likely end up holding in more dirt than they keep out. i ran the dark soul boots with the cat5 rings on mine they are very heavy duty. and i never broke a single diff cup either
Hey pistol, do you know where you can get those CAT5 axle cup rings? I can't seem to find them, maybe there's an alternative? thanks.
i got mine from large scale rc. they don't seem to stock them anymore though. i would try giving them a call:confused:
