Things to swap out pretty much from day one?
almighty15
Bought me a roller TT and as well as changing the servo's what else should I be looking to change or upgrade pretty much right away?
I know the plastic gear carrier needs to be moved to aluminium but is there any other week parts?
I've read that drive shafts are an issue?
gear plate and gears (if they are plastic). great start with those
diff cup sleeves! never have had any center break but the diff and wheels need it!
bearings at the wheel outdrives might benefit from a fresh set. as well the bearings in diff. esp. the rear input drive.
Not sure the TT/MT parts are exactly same NOW , there are PINS in the drive line that are different so maybe TT/MT knowledge crew will help with those details.
Not sure about the TT but the new version of the DR (the 32cc version with the new body, not the flames version) comes with reinforced diff cups for wheels and diffs. Maybe the entire Rampage range received this update? The new cups are brown, not black (the cups on the center remained black so they probably only reinforced the diff and wheels ones).
The diff cup sleeves are way better even if the cups has been reinforced or not. How do you know they have been reinforced or not because they are brown?
There was a discussion some time ago with RampageHopUps when I first discovered the new models had these different cups and this was the conclusion, since there were multiple improvements from the previous models, not the cups. I can't remember now if Rob actually talked to the Redcat guys to confirm or not.
That's more for inner pin strength.we are talking about outer reinforcing so they don't split.its cheap,easy, and gives the driveline strength which equals more.fun time using not breaking....
+1 its a must do reinforcing or not makes a major difference.
