atom3624
Here's a good one, and a tad embarrassing to own up to!!
My FG MT has a Trevor Simpson 28.5 2-bolt reed valve masterpiece with 17000 bhp or something ..... you know what I mean. It's supposed to be the dog's nads, or onw of many ....
I've never REALLY been able to tune it properly since it's initial installation, and enjoy bashing with it so much, I've never REALLY bothered!
I've been onto Ian THE MASTER Oddie, trying to get new clutch shoes, and discussed the issue of 813 tuning and emptying primer bulb.
He mentioned clearly it's not just tune but indicative of overheating as well.
I found another carb in near-new condition, another 813, and after removing the filter, TGN pre-filter and Outerwears for cleaning and oiling, I was fittign the new replacement carb when I noticed ... erm ... something!!
1. I had had an alloy isolator on the previous engine - this obviously doesn't 'isolate' as the idea is to keep heat off, but comes with a teflon 'gasket' which never seals, so you have to fit a paper one in between ....
Neither this isolator nor the standard could be fitted to the reed case, as it's angled up too acutely and the filter wouldn't fit, so I've been doing without ...
Eureka!! Cause of the overheating ... possibly, but not the main cause...
2. I'd still used the same overlong screws that came with the alloy isolator, and must have fitted the filter as a unit, as I hadn't noticed ..... it didn't hold the carby tight!! Air must have been getting in!!
I've kept it without isolator as the reed cases have an inlet, 'though it will risk getting a little warm.
I've (obviously!!) used shorter bolts to align and tighten the carburettor on correctly, then have fitted the filter assembly.
I shall (hopefully) see if there's any change to the performance in the next few days.
I'm HOPING there's a big change, but we'll see.
It wasn't exactly slow!!
I'm amazed I hadn't had an accident. They were probably 5mm too long to hold tightly.
One of life's ... stupid things!!
