J-Revo
I still can't get this motor to run right. I have tried everyting. The problem startet with the idle screw needed to be all the way in to get it to start with the L needle at 1 1/4. As I unscrewed the idle screw I turned in the L needle.
I ended about 3 turn out at the idle screw and 1 turn out on the L needle.
This makes it run to lean. Turning in the idle screw and out the L needle makes it burn through spark plugs like a whore in the red light district!
Yesterday I had it at about 1 turn out on the L and 1 1/5 on the H.
Good idle, nice torque but it won't flat out in RPM at high speed.
It sounds like the H needle are to rich, but I can turn it almost to 1 turn out on the H, but no differense, it stil won't have clean RPM at high speed.
Maybe the L needle needs some adjusting. Maybe I will try to change the 990 carb to an earlier carb, but if that doesn't fix it I'm all out of sugestions.
