RampageCrazy26cc
well after i fix the not geting spark problem..i took the rampage out to see how it was runing ran great for about 20mins then started hearing this knocking sound..so i broke it in shut it off and try to find out where it was comeing from so i check the flywheel nothing check the clutch and turn the flywheel and a bolt fell out behind the clutch
so i pulled the clutch off and seen one of the bolts had came out and was hiting the clutch..im lucky it didnt lock up nothing..but i found other bolt that fit it and im good to go..
just leting you know i would check those bolts behind the clutch
