Throttle linkage setup
Clubin
Build Thread Contributor
Manitoba
I have been asked, so here it is, how I set up my t/b linkages. It just hits the HPI filter a little, but it will not cause any issues. The only thing I did differently was to add another collar as a spacer no set screw used and another spring between the 2 springs on the throttle side to give me a little more travel for my breaks.
Hey there, if you switch the t/b to the opposite sides there will be less clearance issues. Also move the brake to the inner hole and trim off the excess. hope this helps you some.
Thanks Clubin This should get me going .Mine have ben driving me crazy the directions in the book aint that clear plus i have some missing grub screws for my collers don't know what happen to them pulled it out the box that way.So I guess I will be ordering some when I get home.
also don't forget to reset your fail safe for the servo will need to be put in reverse mode if you plan to switch t/b link arms:)
