Throttle linkage
kaztheminotaur
When ever I let off the brake the servo comes too far forward and blips the throttle open a wee bit. Any one else have this problem? I've tried with and with out a spring.
One thing I haven't tried is setting the servo horn forward or reverse of centered and then adjusting the collar to compensate.
I run my throttle on outside of truck and brake towards the inboard. I run the brake more towards the center of horn, for more torque and less travel. The throttle I run as far outbourd hole I have to make more tavel and quicker. I had to reverse the direction on my radio to do this but the kinkage seems happy never any binding.
I had a similar problem. My throttle linkage was binding inside the little plastic piece that attaches to the servo horn (I think dirt/grit got in there). I just drilled the hole out a little larger. Problem solved.
