Throttle not going back
Yessabub
How come when I throttle and let off the servo doesn't go back all the way so the carb is set at idle I have to press the brske for it to set back. Is it suppose to go back with just letting off the throttle? Mine has been stalling a lot when braking quickly but the idle speed screw is fine
Did you recently oil the air filter and then trim the throttle open to get it to run? An over oiled filter reducing your airflow will cause that but your throttle should close unless you adjusted the trim or moved the horn on the servo.
I haven't oiled them they were preoiled but I will clean them and reoil. I don't think I have ever adjusted the trim on the controller how should they be?
My throttle arm was slightly rubbing the side of the air filter, preventing it from closing all the way when you let off the throttle. Give it a quick check
Nope is it maybe through the wrong hole on the arm? It's in the middle one does that make a difference?
