So, I just got my brand new Rampage MT. I installed an aluminum roll-cage and a tuned pipe. Going through engine break in and the throttle servo is going wacko! When engine is not running, everything is rock solid. Works perfect. After I start the engine the throttle servo glitches back and forth, and will occasionally go into the fail safe mode with brakes fully engaged. I got lucky too when it decided to go wide open! I was able to grab the truck and get it shut down before it took off! Im a little nervous to run it any more until the issue is resolved. Any one had similar issues with the stock setup? Ive heard the servos are not that great, but the truck has 2 10 minute slow runs on it. I have not even burned a half a tank of fuel yet. Any help would be appreciated.
Thanks!
Thanks!
