Tire and Wheels
Adamsky
Elizabethtown, KY
I have been waiting several weeks for redcat to get tires/wheels in for my XT and I think I'm done waiting. I would like to put something back on my truck with similar height and width. Can anybody give me some advice and maybe pics? Also what type of adaptors would I need to run proline or HPI wheels?
You can use either 7075rc Hpi adapters (which I use on mine), or you can use Ram-tech adapters. Ram-tech one extend out from stock location. I have both but like the 7075 ones better. Tires- any of the proline ones will work. I have the trenchers (all rears) but find them to be a little heavy. I also run imex j-7 baja tires and wheels but are heavy but are big. Last I also run the MCD monster truck tires. Which are very big and wide but surprisingly light. The newer MCD monster truck ones. Hope this helps a little.
Bigger and heavier tire also mean extra wear and tear on drivetrain parts
For the MT look I like the RAMTech adapters since they widen the track width a bit.
The 5b rear wheels will be the widest. You can mount Proline Treanchers (rears) to them. It is actually a 5t size tire. They still won't be quite as wide as the XT tires. If you mount 5b rears they will be wider but not quite as tall as the trencher.
These are rear Treanchers mounted to rear 5b size wheels.
