tire help
Stay away from those guys many have had problems.
For starters the XSC has square hubs not hex. The truck in the photo is not a Redcat. It is a Baja SC clone. I wouldn't trust it.
thank you for the reply I haven't got the truck yet should be here Monday what would be a good wheel set up the baja 5b front or back or 5sc front or back tgank you again
that is awsome thanks for sharing the 5b fronts will be a little bigger I plan on getting thay body you have like you said it makes the tires look smaller. also how do you like the xsc is it geared the same as the xb
No problem.....
The XSC is nice and light making it quicker.
The XSC uses the same 29-31 gearing that the XB uses.
