cooper1jones
Junior Member
- Reaction score
- 0
Just bought the adaptors from 7075. Any suggestions or experience with larger tires for the xsc. Any advice would be appreciated.
Thanks,
Thanks,
+1 on boiling the tires and you can use these inserts https://www.largescalerc.com/search.aspx?find=010902P0+-+Monster+Tire+Foam+Insert+(QTY+2)cordy said:Boil the tires till the glue softens,then remove the tire, pull out the foams dry them,then put the foams back in put your tire on then reglue.That being said is why some of use beadlock tires and rims.You can get foams at ddm or largescale or as a cheap fix go to walmart and get pool noodles cut and trim to fit.Hope this helps. Good luck.
