Tires blowing out of beadlocks
CyberVet65
Cedar City, Utah
I have read several places where the guys running twin cylinders are h aving problems keeping the tires in place.
I have a Rampage MT with a OBR 30.5cc race ported engine. Runs great. Except for the fact that I have to rebuild the tires after every run. They are coming out of the beadlocks.
So far:
Wrapped all the foams with Gorilla tape. Three wraps.
Silverback Beadlocks
What next? I guess try gluing the foams to the wheels?
Putting RTV on the beadlocks?
Any suggestions?
These are ProLine Trenchers that I am running with Hostile foams.
Help!! Sure would like more than just one run.
A lot of people use glue, DDM has it. Email them, Steve can help you: [email protected]
Also, Try Hostile MXT tires Extra hard compound with Hostile Rear 5B Zero Growth molded foam inserts. They come in Yellow color. These are by far the greatest.
Also, ever tried running BRP tires? They use same tire material of a 1:1 bridgestone
Once you get the BRP tires you have to get the adapters to run them. I have only seen tires for 1/4 scale. Will these fit on a 1/5th scale?
Zero growth foams. I am gonna get a set of these. Then glue them to the wheels. Then wrap them with Gorilla tape. Them use the long hardware to tie them down. If they still come out of the beads then I am going to just cry! :(
CyberVet65 said:
Once you get the BRP tires you have to get the adapters to run them. I have only seen tires for 1/4 scale. Will these fit on a 1/5th scale?Zero growth foams. I am gonna get a set of these. Then glue them to the wheels. Then wrap them with Gorilla tape. Them use the long hardware to tie them down. If they still come out of the beads then I am going to just cry! :(
if im not mistaken, the BRP tires will fit the MT without any mods but will not fit the other X-platforms.
if I were you id ask the forum or email Bishop racing.
however, a lot of people do use the BRP tires on their 5th scale (baja) using special IRP hubs.
For the first time I am not fixing tires! I put the stock ones back on. Two things are immediately noticable. Top end is way down and turning radius is about doubled. But no tire repair.
