To much compression.help pls
rednec
Hey guys
I just upgraded from a 26 cc to a 29cc big bore kit,everything went together well but when I pull the pull start it has way to much compression,
Hmmm, how hard is it to pull it ? If it's so hard the pull that u can't start it u may need to get a thicker shim gasket ...
Sounds like it is normal to me.
If you pull the spark plug & it pulls over easy, with no drag, I say that would be normal.
Coil binding with the flywheel is another common issue after this upgrade, but should be easily noticed once the spark plug is pulled, and the engine pulled over if so.
I got it going boys,it was to much oil that I put on the piston lol.she started no problems, thanks for the advice
