To scared to run truck
MTMIKE
New Haven, In
Installed killer bee2 on stock redcat rampage MT. Everything worked great for long time. Had steering servo go bad. Replaced both servo's with 5755 Hi-Tec and replace Throttle servo with 985MG Hi-Tec. Still using redcat DSM-2C 2.4GHZ radio. Now everytime I turn off power on Radio it goes to wide open throttle and does not shut off. Did a rebind but did not help. I think it has to do with radio but need your advise. Thanks :eek:
Do you still have the fail safe In?
if ur running the stock failsafe get rid of it the killer bee is all ull need...where do u have it hooked up to btw? steering or throttle channel? i had similar problems when i first installed my killer bee v2 with the stock radio on the throttle channel it would cause glitching and wot alot.....on the steering channel it works perfectly .....cuts the engine and applies brakes after i turn off the tx
Get a good 3ch radio! and keep that radio for a 1/8 or smaller car.
I have used Spektrum from the DX3S to the cheaper DX3E with great success.
With the 3ch radio you can kill the engine with the 3rd channel and still be able to steer and brake the car.
