dwarfy
I was suppose to be having a bash with Charlieboy this afternoon but things went tits up this morning. I was charging the 2500mah 'AA' batteries in my new 2.4ghz Core RC handset for the first time (charged them external last time) so left the charger on 500ma and carried on sorting stuff out round the house. After about 4 hours I came back to it & it was fizzing & smoking :helpsmilie: It was that hot the battery cover had melted & I had to prise it off with a screw driver. The batteries were all fooked, the holder melted & the back casing of the handset was damaged :helpsmilie::2guns::2guns: Took all the gear down to Rossendale Models where I bought it from & they put the fault down to the batteries. They were rated to charge at 500ma but there must have been a defective cell amongst them which in turn fooked the rest of them.
Amazingly they tried a new battery holder & cells & the handset still worked fine even with all the heat directly behind the LED display so no problems with the quality of the components :cool2: They are going to speak to Schumacher on Monday & sort out a replacement back casing, battery holder & cover so hopefully all should be good for next weekend. Anyone else had problems with defective battery cells and is there any way of testing them or is it just bad luck?
I met up with Ben up at the track but he was having trouble with glitching so his was a no go as well so all in all not a good day:no:
