Took the XB out to play
Gizmo1
Houston Texas
Little vid of yesterday..
i need to change the diff oil in the front and i also will change out the rear rires to a set Hostile MX's.
the car runs very well and as you can see its pretty damn fast after the mods...
still the stock motor, just changed out the carb to a 990 with inclined shreadstack and added the rear V2 Dominator
[ame]
[/ame]
had a blast with the 4wd, its def. a learning curve from my baja's !!
cats moving right along! Where not having a center diff really shines is clinbing - side hilling- on snow, these cars are sorta like a front wheel drive full size car. they want to drift to the outside.- i back off the gas, then steer-get back on the gas.- The stock fluid in the diffs- not certan what it is- metanol will not dissolve it.- fun- fun. I run 10,000 rear- 7,500 front. Run grp bulldogs narrows on all fours.
It looks like you are having too much fun with your XB lol. That thing is running pretty good and turning even better.
Sounds good. I would change tyres on all for rims and test it out before you change the dif fluid. Gripper tyres will completely change the way it is driving.
Re: Took the XB out to play
I run in grass all the time and since I invested in a slammer dam my motor don't shut off on me from grass jamming up on the coil. Outwerwears work great too but would rub on driveshaft.
