I bought a new KM Baja, got it less than a month ago. I took it out to start it and it would never fire or anything, I did adjust the carb to settings recommended from the forums and still nothing. I ended up breaking the pull start and had to wait for a new one to come in and I ordered a new NGK plug also. After I put in the NGK plug in, it started on the second pull. Looks like those torch plugs are crap and and when you hold both plugs side by sideand compare the ends, you can tell the NGK is a lot better plug.
