torque spec?
Ildy666
Haskell Nj
Any body know if there's a torque spec. On hy 30cc engine head gasket?if there is anybody have it? Thanx Ildy......
on the 2 bolt engines- its 6 to 9 N/M. Example- 8n/m X 0.7376 = 5.90 ft lbs. If you have a paper gasket, be careful- torque evenly- a little bit at a time, Idle the engine - then re-torque. -- while the fan shroud is off- drill 2 holes to acess the bolts.
oh- if you have troubles sealing the 2 bolt up- i can show ya how to do it - you should try to use wide headed bolts- or the stockers with a good grade flat washer- just saying--my humble opinion.
