TPS™ RedRace Ignition '10
RonW
ommen
After many tests now finally available, the TPS ™ RedRace Ignition '10. The unique concept that is thought about and nothing to the imagination allows. We use only high quality components is a reliable operation and a substantial capital guarantees. The system consists of, = stator (coil), confirmations stator, rotor carrier, rotor = (flywheel), stainless steel rotor nut, and a high voltage condenser coil. The stator is based on two CNC machined crankcase bolted through the bolts. The rotor is attached to the CNC machined carrier, with a special stainless steel nut on the crank shaft is put down. The CNC machined heatsink sits with two M4 and M5 on the rotor and a rotor nut attached. Because the rotor is much smaller than the original flywheel, the cooler a lot lighter, and the shape gives a much better cooling and the spark is much more powerful, each engine provides more power and quicker acceleration, without further tuning. All cabling is attached and is made with high quality silicone wire with shielded connectors. The installation is very simple by separate Dutch building instructions with clear pictures. Fits all Zenoah, HPI Fuelie, CY and Pitstop Power engines.
Hmmm, this looks good. How much does it cost in USD? Does it come with a warranty?
China Clone?
Abbate and Modellsport from Italy where the first for a BIG price, we improved the system, and set it on the market for less money! **:)(€ 149,00):)**
Regards,
Harrie
Yes, we deliver with full guarantee. You can be sure this is a realy good sytem for USD 192,90!
Regards,
Harrie
i love this kit its at the top of my i want list it will go nice on my oddified23cc engine cant wait santas coming guys and ive been a good boy all year so id better get it or im eating rudolf on boxing day
