Traxxas monster buggy wheels
Roco
Looking to upgrade the wheels and tires I’m assuming the hex is 24mm, anyone have any links or ideas on a set? This is what is on it now, and on the fuel tank I think I can get away with just replacing the two fittings where the lines come out.where would I get them? Or if anyone has a tank I’ll buy it, Thanks 410065CB-61A2-42C6-BDBD-5B93E708D2DB.webp
The wheels that are on that are from a cen genesis 7.7 and yea any 24mm hex wheels fit. Also any pictures you can provide of the tank so we can see what needs to be replaced?
Thank you I will get that picture up right now. Thanks for the help and those tires that are on it right now I had stored away and they were out in the weather somehow and they’re all cracked and split so I’ll probably just get another set of those they look pretty cool on their butt. Let me get that picture uploaded real quick.
I might need a cap also I’m not sure where this one is but the main thing is the fittings that the hoses go into I’ve got new hose with filters. It came with the new carburetor, but those fittings are all dried and cracked..7DC32C5C-834B-4462-9C25-6C02FA84683E.webpBE0C0F8B-F412-49E6-A359-401ADFEB7DE4.webp
No problem. For the wheels I'd run baja 5b buggy wheels on that, they would pair up nice as that's a buggy as well.
What hubs would i need to run? Do you have a part number? I was able to find some Arrma 17mm hubs with an 8mm axle but the set screws are so small they wont stay tight on the axle. i even drilled it for 2 and they still come loose
