traxxas reciever
oldmanhayes
Junior Member
Hello all,
I just got my first 1/5 scale from rampageshop and was wondering if I could use a traxxas rx/tx in my new rampage mt? Any suggestions would be great.
thanks
That depends on which kill switch you plan on using. I believe RCDAD has a kill switch out, and so does Rob. But I'm not sure if they're compatible with Traxxas systems. I know the Killer RC switch can be used with Traxxas systems, but you might not be able to use certain features like the glitch kill. You'll still be able to kill the engine by turning off the radio, and I believe you can use the third channel kill, as well.
Yes you can use the Traxxas electronics. You need to run a remote kill switch. As Deluge stated. The killer bee is the only one that will work with Traxxas because you can turn off the glitch feature. Ours and the RAMTec unit come preset.
I have a killer bee kill switch and was planning on hooking it up to the third channel.
thanks for the feed back!!
