TT buggy
Obeast44 said:
Also, in case it hasnt been mentioned. Stock HPI Baja 5b Rear hubs will bolt on the Rampage on all four corners allowing you to use wheels/tires designed for 5b. Im using Pro-line Desperados and Hostile MX v2s all around on mine and they are without a doubt the longest lasting tires made.
do u have a pic of it?i thot u need an adapter in order to use a hpi baja wheels?
you can use stock hpi wheel hexes. you would need 2 sets of hpi rears. or you can do hpi axel extenders for the same price. these are mine from vertigo. they are 8mm wider. the second pic is proline desporatos for the 5b mounted on a rampage MT.vertigo axle extenders 003.webp
/monthly_2009_06/583c6059e08d6_vertigoaxleextenders003.jpg.c5b077109b1c73594cb9b0300d320971.jpg
/monthly_2009_06/583c6059e1bae_thewidowmakerproject024.jpg.2d5daca592ff99f5a51590c8c45acc13.jpg
hey krypto!
i sent you a pm. hit me back when you get a sec.
kryptonite said:
i got it bud. im going to check you out over there when i get home from work!!
Thanks Krypt for getting on that, im slow as crap in the pic department :)
I used stock HPI Baja SS orange wheel hexes cause I got 4 for $12+shipping!
