TT Tires On Asphalt
hamster huey
Wichita
How do the TT tires hold up on asphalt? I am considering a onroad rally style build and if I bought the TT I would either use the stock tires, mcd rally sedan tires if I can get the adapters, or bowties. My first choice is the TT tires becuase they are no additional cost but if the wont last Ill sell them new and get something else.
I ran for almost an hour on the road and parking lot, lots of power slides, drifting style corners and some donuts. several high speed runs with sideways sliding to a stop. all in all for a pin style tire they have held up well. starting to feather the nubs and angle them back, outer ones are worn pretty good. then ran in the grass and dirt and still worked well, I may rotate them after the next run, but for as much abuse as i've put them thru and on a surface they were not meant for, they still look good.
that being said... they wont last for long being run only on road, you would be better off with a real on road tire like krypt has.
yep to the hostiles. Do you know there diameter? I know the bow ties are very good on/off through experience and have a dia similar to the TT. Its been hard to find buggy size or smaller tires that are good on/off like rally tires.
