Tuned-pipe Choice
Dongskie
Mandaluyong City
Just got the jetpro on my redcat chimera. Beast right after the install. Noticeable difference, and that sound gets people looking out their windows.
neither of those pipes will fit your d/r without being modified. the jetpro is the only one I know of that is a direct fit and both are made of aluminum which I would stay away from anyway.
I melted an alloy Ghost after 1 run and tried the steel one which kept blowing out coupling gaskets.
They're very easily fitted to the DR
I now run a Jetpro rear mount and couldn't be happier.
Kaceno is right - they are LOUD
Thank for the input guys! :)
Yes, sadly noise will be a concern :( , but I do like the rear mounted version :D .
Phill said:
I melted an alloy Ghost after 1 run and tried the steel one which kept blowing out coupling gaskets.They're very easily fitted to the DR
Phill do u have a pic with one of those pipes mounted and what did u have to modify to get them fitting
rcgasser said:
The rear mount with the silencer is what I run on the DR its a BEAST!!!!!!
Where did you get the silencer for the jet pro rear mount? Does it have a negative effect on performance?
