Nope..... I never cut my body and ran in with the posts set as high as they go and burned a quarter size hole in my body whee the pipes sits at its highest point I suck at cutting in fine detail so where it burned it actually looks like it was made like that...James1996 said:thanks for the pics didnt think you had to cut the bed of the truck, could you get away with it by adjusting the body posts
I have my posts set at stock level or a bit higher. I cut my body with my dremel which worked good but I kinda FUBARed the bed. But, it still came out pretty good. I have my posts pretty high, and still had to cut it that much. Plus I compensated for when the truck is going and the body is rattling. I love my CPI as well. I didn't like the look of the Jetpro's etc hanging off the side of the truck. It's a much cleaner look plus the truck is still a beast.Trickle007 said:Nope..... I never cut my body and ran in with the posts set as high as they go and burned a quarter size hole in my body whee the pipes sits at its highest point I suck at cutting in fine detail so where it burned it actually looks like it was made like that...I love my CPI pipe because of the rear exit to me it looks less likely to damage a rear exit pipe opposed to the side mounts.
