If you want a direct bolt on, contact Rob with Rampage Hopups. He can get you a Flowsystem pipe. It will fit under the body also.tdcdvideo said:Hey guys any recommended tuned pipes for the rampage xsc? Thanks
Takes a bit of work but is doable.-Deluge said:The most popular is a modified DDM rear Dom.DDM Dominator® V1 Chrome Pipe w/FREE X-Port for HPI Baja 5b/5t
OMG... love those tires... where can I get them for good price?RCDAD said:Takes a bit of work but is doable.--
Wow... are these for off road or are they consider all terrain? Do you have to glue the foam or simply place them inside the rim? Does the tire swell up at highspeed RCdad?RCDAD said:I bought mine from DDM. http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.5482/.f
And these tires should in any baja 5b rims?RCDAD said:I bought mine from DDM. http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.5482/.f
They have not been run yet. That truck s still under construction. LOL. They might balloon a little because they seem soft.ChuenouXiao said:Wow... are these for off road or are they consider all terrain? Do you have to glue the foam or simply place them inside the rim? Does the tire swell up at highspeed RCdad?
They fit the 5b/5t front wheels.ChuenouXiao said:And these tires should in any baja 5b rims?
The 5T Dom? It's a nice pipe, but a pain in the ass to work with. I have one on my 5T. You can't get to the radio box with it on.Dcc079 said:Had anyone used the dominator that wraps around the cage? On an xsc
