Turnbuckle ends
Rcflyer55
New York
I broke the ball link/ rod end on the end of the turnbuckle that goes from the spindle carrier/ hub to the bottom of the shock tower.
I can't find that rod end anywhere. All I see is the pack of 7 turnbuckles for $50.
Any suggestions would be great.
LH thread
Plastic
The turnbuckle is 7mm so I guess M7 can't find any specs omit and I waited over an hour on hold with horizon hobby then used the call back option but never heard from anyone.
This is the part I need
The stock turnbuckles are the way to go. The dgi pieces are garbage. If you buy the set of turnbuckles from horizon, you'll have all you need for a while cuz there's more than one of each piece. The metal ones are not very convenient when one breaks. Well, anything breaking isn't convenient but speaking from experience, the dgi turnbuckles are just not thick enough to hold up the 30lbs of vehicle. What needs to be manufactured is a metal version of the stock rod end. Are you listening Area RC!!???
