46u
Been running my TR clutch system on my 5b SS for 3 years and like it very much an in my opinion is the number two up grade only after a remote kill switch. Up to this point I have been running stock gearing. Being I installed a engine I built a race ported 30.5 I felt the need to gear it higher as the low end is all most uncontrollable and more top end will not hurt. So I got a Hostile 56 spur with a TR 18 pinion. When I installed it there was WAY too much binding and the gear mesh was way off. After playing with it for a couple hours I emailed Rob at Hostile and this was his reply. I meant Rob at a race a couple of years ago and he is a GREAT guy.
Hi Jeff,
The Turtle 18 and 19 tooth pinions are not industry standard and that has been causing issues for us and our customers. All of our spurs, 54, 55, 56 and 57 are industry standard and mesh perfectly with all corresponding pinions that were made industry standard as well. The Turtle 17 and 20 are the only properly size pinions, that is why the 57 meshed fine with the 17. The DDM “Black Magic” pinions and the Vertigo pinions all use industry standard so they mesh perfectly in all of the standard combinations.
Some people that don wan to switch from the Turtle system are using our 55 with the Turtle 18 and 19 loosen the mesh up. The mesh is not perfect and has more play than we like, but our gears are pretty tough and hold up to the incomplete mesh.
My apologies for the inconvenience.
-Rob
Hi Jeff,
-Rob
