Ultimate xb-e
twissted
Omak Washington
RampageXBE-T012_zps2de31d0f.gif RampageXBE-T015_zps60dfedce.gif XBElosi5010_zps84bee238.gif XBElosi5009_zps13fa2298.gif XBElosi5003_zpsa0b31444.gif XBElosi5014_zps064e433c.gif
This is a stretched XB-E that is currently getting new diff housings in front and rear they and the wheel hubs are made by 7075rc. 24mm hex adapters are Ramtech and the motor is the beast 524 2Y 910 kv motor with 200 amp esc that has caps added running on 8s Nano-tech 65-130c 5000 lipos. carbon fiber body is vac bagged with impact resin making it 18 time stronger than the losi body. And is lighter to boot!
The front shock tower is 6mm and is using 2mm and 4mm epoxed with gorillaglu.
I'm still shaping it.
I waiting on some bearings as well. Also I'm waiting for Doug (O'l fart) to send me a milled chassis for this build.
The TLR shocks are stock valved with 35w oil to start with. I built them using the rear long bodied shocks all around.
So here is the Maiden run. I put he camera on board.
enjoy!
After this video I loosened the pinion gear and installed the matching blue springs on the front. rear was already blue set. it was to soft on front.
Thank you. I have it torn down for the moment. I have to get some new parts to get the ride I want. I'm going with cnc lower arms. The XBE arms are not holding up. rears seem ok but I'm doing both.
losi cage side. cnc lower arms new rear cage mount, new hing pin and replace bead lock. new custom bracket for rear cage mount.
I repaired the front shock tower. It was de-laminated from the impact. I used a stronger epoxy this time. Marine epoxy is white in color so it has to be cleans up better before it dries I'm happy with how it turned out.
Here are some picture of the fracture cracks.
I have the rear cage mount tabs to repair next.
I fixed the roll cage by drilling a hole and using a long thin screw to hold it in place.
