Twister
Junior Member
Ok, I Loctited (
) almost everything, 3 long screws on the gear side, 2 grub screws on the shaft (have to get a longer key for the 3rd middle one) 8 on the wheels and 4 on the front and back sway bars.
Now........
Besides the fact I have a screw left over (same size as the one's holding the gear cover on, will have another look tomorrow, getting tired) I also found this (pictures) under the pull start, I don't know where it goes and was just removing the hex screws, gear cover, and plastic sides so don't know if it was sitting there all along, only saw it when I looked underneath, it isn't a broken piece or anything. Don't see it in diagrams anywhere Any ideas ?
So after all that, there are a few things........
In the manual (and I'll use that term loosely) it say's about setting the clutchbell and spur gear and loctite the 4 engine screws, I don't see any of this so I take it this is the guide for the Nitros ?
Also they say the break in should be between 20-1 and 25-1 for the first few tanks, in the "manual" and on the side of the engine it say's 75% gasoline and 25% oil, now that can't be right but thought I'd as in case I'm missing something.
I got the Amsol semi-synthetic oil to use, they don't carry Lucas 2 stroke here.
Thanks guys
Now........
Thanks guys
