Unbalanced Tires
Cy25
Junior Member
Mill Hall, Pa
I am running a Rampage MT V3 and I have noticed a good amount of wobble in the stock tires. Mostly when you set it up on a block or something to try and clean it out during tuning. Is this just how these tires are? Is there a way to balance them out or is something loose on my vehicle I need to check? Or is this one of the main reasons people go to the HPI conversion?
P.S. I figured I made this account so I might as well use it so yes this is my first post on here. More to come as time goes by. I have basically a stock V3 with a home modded exhaust until I can afford to upgrade.
Ok I made a mistake and posted this in the wrong section. If a moderator could delete this and I'll post this in the correct section I would appreciate it. Thank you
