DemonRC1
My main trade is a software developer which means I'm also digging into CPU's on a regular basis. I'm always ordered "name brand" CPU fans with high CFM's (air flow) with LED's and all that. Typical medium flow fans in the 40mm range which is what our ESC uses draw about .08 amps. Higher flowing fans around the .12 to .15 range. That's pretty minimal over a typical 15 minute runtime. So.... I want a cool looking fan. Here's what's on order. It's a 3 pin setup which I'm pretty sure the 3rd wire is used for RPM. You should be able to splice it to the "hot" wire and just run full RPM the whole time. Our fan cover is transparent so a LED setup would look pretty trick. This unit flows 8.8 CFM. There are some that flow 10+ that are brushless but they are a little loud. At least inside a office comp. In a car it doesn't matter. Anyways here's a list of a bunch of fans that fit our ESC. Also, you can stack these mofo's by using longer bolts. You have to do a wiring job if you wanna stack em. http://www.coolerguys.com/401.htmlhttp://www.coolerguys.com/840556086833.html
P.S. If you don't wanna jack with the 3 pin, just get a 2 pin like the stock fan.
