theres nothing wrong with the ignition system as long as u gap your plugs.What upgrades are there to the ignition system for the fuelie 26? Can you make it adjustable or more accurate?
That key will advance or retard the timing by 2deg.. There are guys who believe in them & others who don't. It is called a Rocket key sometimes. I'll post a link to another ignition option. I really hope to get one of these & try it out. MSD is a very good company in the racing world & I would bet this is a good set-up. As for the key design, I have had guys tell me that it will allow the engine to over rev if you don't watch it. They tell me it can explode the engine !? Don't personally know, never used one. I get plenty of performance out of my engines by proper tuning & pipes.
Give it a look ...
http://www.gopeddepot.com
Go to Fast Parts, Then on the top bar in that catagory go to far right to MSD ignition & flywheel.
MSD Ignition & Flywheel
MSD Kicker Ignition & Billet Aluminum Flywheel
The MSD Kicker Ignition designed for Go-Peds® and Go-Quads is the latest addition to MSD's full line of ignition systems. The Kicker Ignition comes with the same proud racing heritage that all MSD products are born with - tough, durable, accurate. On a Go-Ped® there's lots of banging around & vibration - our Kicker Ignition is built to take it and still deliver a hot spark! The MSD CDI box is completely sealed and potted with a high density ResTech Polyurethane Potting Compound. This makes sure that the internal components are protected from all the hazards that riding a 'ped can throw at it: vibration, water, dirt, fuel, etc.. The Kicker Ignition makes timing a lot easier, and a lot more accurate than the stock coil/pickup. You can control the retard rate from 1/2° per 1,000 rpm up to 1° per 1, 000 rpm with a simple timing adjustment screw on the MSD CDI box. Add the MSD Billet Aluminum Flywheel, and you'll have the most complete ignition set-up ever available for Go-Peds! With the MSD Kicker Ignition's hot spark, and adjustable timing, your Go- Ped or Go-Quad will really move out ahead of your competition.
Give it a look ...
All I will say it requires a 7.2 Volt rechargeable battery. That is heavy.
What happens when it is discharged no ignition?
Fore the added Wight it must give me 1 HP at least. To compensate for the extra Wight and some power that I can feel. Other wise whey bother?
It will make a difference in big engines, not ones as small as 30.5.
