upgrades
Alloy diff cups all round, and front/rear diff housings are essential. Diff housings need to be the RCMAX pro-am as they have the bigger bearings. You might be able to get away with the Chinese housings, but will deffo need the MOD rear diff inserts
Alloy chassis braces would be a good idea, a 50gt weighs 4.5kg, compared to small bore cy/zenoah at a bit over 2kg
Rear shock springs, i use the IRC black springs with 70wt oil, that seems ok. The stiffest Losi springs might be ok
Drievshafts will hold up for a while, but you'll need the Phatdads eventually
*edit* And the Modified RC centre diff mount, not only for the larger bearings, but the wide feet for a solid mount
