upgrading engine
maddmike
What's the most cost effective way to get more Rome and maybe more power front stock engine. I already have 7500 rpm spring on and rear mount dominator but want more rpms
Search around this forum, lots and lots of posts on pipes
Jet Pro seems the way to go for RPM's but I prefer the mid range and sound of the CPI
To gain cheap Rpms I out of a stock engine the easiest way is to pull the head of it and buy a die grinder. Lighten the piston Raise the exhaust port timing and match the case and head for better flow. Remove the flywheel and shave the fins down to lighting it as well. It's not difficult to do and will help gain some higher Rpms.
Well besides porting. Can I pick up a new head kit or get a lightened flywheel or something like that. Want to upgrade to obr but gonna get all I can from this one
