Tbone4life
- Reaction score
- 4
I've recently bought an older used Rovan with 36cc engine and it keeps breaking the pull starter. I'm on my 3rd one now and could use any help or advise on what to do? Thanks for any help.
Also wondering what was breaking.where about on the pull start is it breaking?
Yes, that is what I do. I pull easily until I feel the pawl lock up with the magneto, then pull on it. It has more compression than any weed eater or chainsaw I've ever started. It will run though, I got it running one time, and it ran well.First thought is you don't need to yank on it like you want to kill it. I generally tug it kind of easy especially the first few inches until the pawl is engaged.
Not sure if this is the cause but just thinking out loud.
Yes, I usually put blue thread lock on almost every bolt or nut I take off. It should be here sometime tomorrow and post up the results.I have seen that setup as well but know nothing about it.
Only thing I question is the added weight to the flywheel itself when that pawl assy. is bolted on. Most try to lighten and not add weight , not sure it makes any difference though.
Only suggestion would be some threadlocker on those two bolts.
