They don't take the gears off frees right upTake it apart and make sure the gears turn freely.
Ya soon as I take the gear off it frees right upDoes the shaft you took the gear from turn easily?
Both set bind upAnd this is the gear closest to the motor,right?
@Bully6980
Your description is a little vague.
1- take out all of the gears
2- mount the first one. The one on the clutch shaft.
3- spin to see if it spins freely. If yes, go to step 4. If no, then you know where the problem is located.
4- mount the middle gear (the one in the center of the transmission plate).
5- spin to see if it spins freely. If yes, go to step 6. If no, then you know where the problem is located.
6- mount the last gear (the one that connects to the brake assembly).
7- spin to see if it spins freely. It shouldn't spin freely since you have a problem. At least you will know where the bind is located.
Investigate starting from there, going through the brake assembly.
Ya everything thing is stock that was the first time I drove it
