Peteolheadz100
- Reaction score
- 23
I took out my vekta 5 to run today and during braking airen 2 tanks of fuel and it ran perfect. When I went to start it back up on the third tank of gas it will not start not even a pop when the choke is on. I changed the spark plug, I checked the ignition coil took the engine out inspected everything the fuel lines are receiving fuel and the return line is going back into the tank with no issues fuel lines are good, the carburetor I have not touched since it was running fine I have no idea what else to check I pull and Pull and Pull and not even a pop like it wants to start remove the spark plug checked if it was flooded pulled it a couple times it seems to be fine not flooded. Any other suggestions on why this won't start anymore?
