xscrick
anyone run one in there king motor,, im building a dirt oval car out of a 001,, are the outdrives tight to the locker and bearing,, mine has .025 thousands space on both sides, diff slide back and forth in the trans case ..thinking I may need to use hpi outdrives instead of km,, should be fun when done, built a engine with a obr 27,2 4 bolt Zenoah prostock head on a cy f270 crankcase with fast eddy bearings,, running 3 open bearings with the turtle / obr clutch case,, hoping diff locker will be perfect fit into this project when I get the bugs worked out
