Vertigo HPI wheel adapters Installed
Slasher
i got them installed Today Vertigo extended HPI wheel adapters
tell me what you think
My Proline Desert Rat Body Will Be Here Next Week
here are Pictures
That looks sick. Btw don't I need those adapters for my coming hpi wheels?
Also bro you have something really good coming there. Good luck on it
Slasher said:
yes you need these adapters
HPI Wheels are 24mm Hex Rampage Has 23mm Hex
but you can use the 23mm wheel nuts off the Rampage
Use this code at the following Link to get 5% off your order --> HBF
here is the link
http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.3495/.f
HPI rear adapter are about $25 shipped all 4 on ebay. Theyre standard, not wide but they do the trick.
I think dark souls has some too?
Slasher, since your MT is new(ish) to you, you should put way more holes in that gear cover unless you plan on never running more than a tank or two before a FULL cool down.
I finally melted my C & D after a couple hours of bashing with minimal (10-20 min) cool down here and there.
