GCLaredo207
Junior Member
Hey all. I am new here. I did search for my problem on here and did find some info, but I did everything I read about and am still having issues with my Rampage XT. Hope someone can help.
The steering was very weak on my XT. While driving around the truck would barely turn. While on pavement or grass.. Very weak. To the point that it was hardly drivable. While at a stand-still, if I lifted the front end off the ground and steered the thing, it would steer fine. It's as if the stock servo was too weak to steer the tires with all that weight on the ground. So.. I went out and bought the following:
Venom 1506 5-Cell 6V 5000mAh Baja Receiver Hump Battery Pack
Hitec HS-5645MG Digital High Torque Metal Gear BB Servo
Hitec HS-5755MG Digital Metal Gear Giant Scale Servo
I replaced all the stuff a few days ago. Had to modify a part to get the steering servo on, but it's on real nice.
Throttle servo was easy. Battery pack was easy too. I had to cut the connector off the old battery and solder it onto the new battery as the new battery had a different connector on it to hook up to the truck.
Anyway. Got everything installed. Same issue! Ugh.. I don't know what else to do. The steering servo works great when the front end is off the ground. It's fast now. Sounds nice. But while driving around, it barely turns. VERY weak. Did I buy the wrong servo? The stock servo reads 32 or 34 kg on the back. The new servo I bought is 24kg? But all the forums say to use this servo. Maybe it's weaker than the stock servo? I'm confused.
Ever run into this issue?
Also.. I upgraded the radio system a few weeks ago. I bought a Spektrum 3XDS transmitter to control all of my trucks. I put one of the receivers in the XT ( a non-telemetry receiver). This shouldn't matter though. Works ok. I get some interference and the truck sometimes takes off on it's own, but I can work on that. I almost totaled it against a cement wall!
Anyone have any ideas? Doesn't make sense.
Thanks,
AJ
Thanks,
AJ
