Volcano epx
morbid9
Junior Member
Ei guys how much is a stock battery suppose to last on the volcano epx?and is it true if you get a longer lasting battery u can fry the engine?my battery gives out like in 6 to 7 min....can you do a bypass to add 2 batteries?
You can go up in mah just not volts. As long as you don't over heat it longer run times won't hurt the motor.
Ahh ok cool,well I got some information yesterday,is it true sense the battery is 2000mah and the charger that comes with it is 250mah,is it true that it will take 8hours to fully charge the battey
